Could be a vacuum leak, spray around the vacuum lines carefully with carb spray, if the idle changes, you found a leak. Also clean the inside of the throttle bore (around butterfly) with carb cleaner and a rag, this will help stabilize idle, as well as cleaning the Idle speed control motor with carb spray
SPONSORED LINKS
Wednesday, February 20th, 2008 AT 7:59 AM
