HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
626
Engine
Symptoms
Stall While Driving
1994 Mazda 626
DCMEZA
MEMBER
1994 MAZDA 626
1994 Mazda 626 4 cyl
The car stalled while driving. Replaced plugs, wires, cap and rotor. Distributor has power. Won't sart
Tuesday, May 4th, 2010 AT 10:26 AM
KHLOW2008
MECHANIC
Hi dcmeza,
Thank you for the donation.
You mentioned the distributor has power, do you mean sparks are available?
If yes, get the fuel pressure checked.
If no, check if the timing belt is good.
SPONSORED LINKS
Tuesday, May 4th, 2010 AT 1:58 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
Mazda 626 Stalls
I Have A 1994 Mazda 626 2.0 5-speed. I Just Got A New Catalytic Converter To Pass Smog - It Did - Hc's Were High (1 Point Below Max...
Asked by
kevinG
1994
MAZDA 626
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
Car Stalls When Put Into Gear
Just Had A Transmission Fluid Flush And A Rad Flush 3 Days Ago And Ran Fine For A Couple Days Until It Began Stalling When Stopped At A Stop...
Asked by
tkg87
1993
MAZDA 626
1993 Mazda 626 The Engine Sputters, Shuts Down..
My Mazda 626 Worked Great Until A Week+ Ago, When The Engine Sputtered (doing Low Speeds In Suburban Neighborhood) And The Engine Stopped...
Asked by
davesac11789
1993
MAZDA 626
2002 Mazda 626 Starts, Shuts Off, Will Not Restart
My Mazda Starts, Immediately Shuts Off And Will Not Immediately Restart. Sometimes It Restarts After Minutes, Sometimes After Hours And...
Asked by
leenette
1 ANSWER
2002
MAZDA 626
1998 Mazda 626 Engine Dies When Pressing Clutch
The Engine Was Replaced With A 30000ml Driven One And After That The Problems Started. Only The Basic Engine Is New, Manifolds And...
Asked by
fdqx
1998
MAZDA 626
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Honda
Code Read Retrieval/Clear Chevrolet
Online car repair manuals
