manual transmision when I press in the clutch I hear a slight chattering noise while the engine is on
172,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
FBRONCO
When I press in the clutch I hear a slight chattering noise while the engine is on, also, it feels as if the transmission is trying to engage even though the clutch peddle is fully depressed. Once I take it out of gear the transmission will not go in to any gear unless I shut the engine off, then restart the engine in the gear selected.
Sep 29, 2016 at 11:33 PM
HMAC300
  • 48,601 POSTS
sounds like the clutch is shot unless you can adjust which I do not think this model can as it is hydraulic.
Sep 29, 2016 at 11:46 PM
