Depends on how many miles on each what has and hasn't been done repairs that need to be made on each.The touareg is expensive all around.When you get brakes done you have to get pads and rotors replaced very expensive.Also when things break there very expensive to fix.If you think you can afford a used one by buying a old one like that.the maintenance and repairs could really add up.I know the vw is expensive to own new or used.BMW's aren't cheap ether to own new or used.If your trying to find a affordable way to own one if that's what your trying to do then I think you will be dissapointed.Not sure your situation etc some people think I can't afford new one but a used one I will really be able to afford but when the repairs and maintenance happen they wish they never did it.
Feb 17, 2016 at 11:46 PM
