MAF sensor fault after brushless car wash
200,000 MILES • 1.6L • 2WD • AUTOMATIC
KIMALEX35
Recently I took my car to the car wash, which is brushless (don’t know if that matters) But I think I made a huge mistake by not turning off my engine while the car was in the machine. Noticed the car suddenly had rough idle and when the wash was over, and I put the car in gear and hit the gas it just stopped. Spent quite a while before getting it started again but once it started it worked fine like nothing ever happened, but the next day I got a check engine light and a code that told me it was something wrong with my MAF sensor. Changed the sensor today and now the check engine light is gone. My question is, what happened? Did water destroy the sensor?
Feb 11, 2022 at 4:00 AM
SQM
  • 6,383 POSTS
It is possible that water somehow got in through the intake system and got the mass air flow sensor wet.
A wet MAF sensor will not function properly and will likely turn on the check engine light.
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
So, since you have changed the sensor, is it running normal with no issues?
Also, it will be a good idea to check the oil and make sure you do not have any water in it.
I have not seen this issue before with the car wash, but it is possible if everything lines up just right to have water into the intake through the duct.
Let me know if you have any questions.
Feb 11, 2022 at 6:01 AM
KIMALEX35
It’s running normally now. No problems at all. Still no check engine light! Haven’t checked for water in the oil jet. I will do that tomorrow. I’ve seen some people experience similar situations as me on forums. Link below:
https://mbworld.org/forums/c63-amg-w204/386046-engine-stall-during-touchless-car-wash.html
Feb 11, 2022 at 9:31 AM
SQM
  • 6,383 POSTS
Let me know what you find when you check the oil.
Feb 11, 2022 at 11:29 AM
