lowest pulley is not turning.
2005 PONTIAC
180,000 MILES • V6 • AUTOMATIC
DANKSTER68
Bottom pulley is not turning. It's also making a loud noise.
Dec 29, 2015 at 5:01 PM
WRENCHTECH
  • 20,758 POSTS
If the engine is turning but the crank pulley is not that means either the pulley came loose on the crankshaft which would have ruined your crankshaft and basically the whole engine or if it is just the outer part of the pulley that is not turning, then the pulley istelf would be bad and easily replaced. It's called a harmonic balancer.
Dec 29, 2015 at 6:20 PM
