Low oil pressure warning light and alarm
2007 CHEVROLET TAHOE
230,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DERRICKGIPSON
Engine runs smooth and engine has oil pressure and no leaks, I've put in a new oil sensor and had the oil changed and filter and the light still comes on and gauge reads 0, but at times the gauge will shoot up to 40psi then it will shoot to 0, at times but engine purrs with no knocking or anything it's driving me crazy cause I've got oil pressure and truck is running great
Aug 2, 2015 at 5:21 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
manually check oil pressure with a gauge it may be the wire is shorting out
Aug 3, 2015 at 7:31 AM
