Low MPG
121,500 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
BUJAR
  • 33 POSTS
I get about 36 mpg on motorway and it is a 2l diesel and about 18-20 mpg in city. But the car does not feel like it is drinking a lot of diesel. The computer is reading low mpg. Why its that?
Nov 22, 2018 at 5:24 AM
  • 110,248 POSTS
A computer is an electronic device and like anything else, they can fail. If you think the computer may be wrong, do this.
Fill the fuel tank. Write down the mileage on the vehicle at that time. Drive the vehicle until you use at least half of the fuel. Refill the tank and note how many gallons were needed to refill the tank.
Next, look at the present mileage and subtract the miles that were on it the first time you filled the tank. That will give you the miles driven since the first fill up.
Take the miles driven and divide it by the number of gallons needed to refill the tank. That will tell you your average MPG.
Once you do that, determine if you are averaging what the computer is telling you. It should be close.
Try that. Sorry for the math lesson, but I did not know how else to explain it. LOL
I hope this is helpful. Let me know if you have other questions.
Nov 22, 2018 at 12:38 PM
BUJAR
  • 33 POSTS
Thanks for your reply, but I adjusted the cam belt because the car used to smoke blue when it was idling. Now it is fixed but the mpg has gone down. I have driven on motorway same journey as before and it took me like 7.7 liters for 100 miles and before it used to 9l something like that.
Nov 22, 2018 at 3:47 PM
  • 110,248 POSTS
Interesting. The smoke was most likely the result of too much fuel. Has the smoke stopped?
Nov 23, 2018 at 6:48 AM
STEVE W.
  • 15,418 POSTS
If you adjusted the camshaft drive belt you also altered the engine timing. That is not something you should do as that alone will cause excessive fuel use. Blue smoke is usually due to bad valve stem seals or on the VW's a bad PCV valve system or bad turbocharger seals that let oil into the system. I would start by setting the timing back to original. Then remove the turbo and look for signs of oil use. To test the PCV system is easy. With the engine running remove the oil filler cap. If the system is working it should come off with a very slight hiss from a vacuum. If however you can remove it and oil mist and vapor comes out, and if you set the cap in the hole it tries to lift at all the PCV system is faulty.
Nov 23, 2018 at 8:12 AM
BUJAR
  • 33 POSTS
If that was not the problem then how did the car stop smoking?
Nov 23, 2018 at 7:03 PM
STEVE W.
  • 15,418 POSTS
The altered timing has lowered the intake vacuum enough that it is not drawing oil past the seals.
Nov 23, 2018 at 9:52 PM
