Hi, I hope this is the right area. i have the car listed above, I purchased it with almost 116,000 miles on it. I used to have a high idle I went to fix my front motor mount and when started to drive home once it warmed up it started vibrating at the stoplight. when it warms up it vibrates when in idles and reverse. I changed spark plugs and fuel injector and carburetor cleaner. i don't know what else to do the check. engine light is not on and when they plug in computer checker nothing comes up. does anyone have ideas? i have also recently replaced cabin air filter and air filter. i did an oil change and transmission flush. also replaced a engine coil (which check engine light came on for) and serpentine belt and also my front struts.
Apr 14, 2019 at 7:05 AM
