Less than 1,000 RPMs. When it's warmer outside it's normal, it does fast idle first at 1,500-2,000 after will go down.
but when it's cold it does not go to 1,500-2,000. No check engine light no flashing check engine light and no codes.
When that happens, I will shut off the engine and after a few attempts it does fast idle at 1500-2000. I believe if I do not shut off the engine the fast idle will go up slowly to 1500-2000. Also, when it happens, I smell a very strong gas smell.
Also, when that happens, I tried to push the gas pedal to see if the fast idle goes up, but it does not.
Dec 6, 2023 at 6:14 PM
