Low beam headlights very dim high beans are fine
200,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LAURIE WLASZKIEWICZ
Low beams dim. High beams are good.
Jan 22, 2017 at 11:11 PM
LOU P
  • 118 POSTS
Hello, I would replace the daytime running lamp relay, the low beam power flows through the relay when the lights are turned on. it sounds like the relay is stuck open and not closing. also, check the fuses LH-LWR and RH-LWR and make sure they are not blown. Lou.
Jan 23, 2017 at 1:28 AM
