Loud ticking noise around engine and jerking sometimes while shifting
118,000 MILES • V6 • AUTOMATIC
STRUGGLER117
When the vehicle is in idle there is a ticking noise and when we accelerate you can hear it too. Sometimes it is quiet but mostly it is so loud that you can hear it even when you have the windows rolled up. We've had it taken to many mechanics that say its normal or they can't figure out the problem. And just this morning it started to jerked once when accelerating and wouldn't go past 50 mph when stepping on gas. Not sure if it is related or not. But i would like to know what the causes are and how i can repair it.
Jan 8, 2019 at 1:31 AM
STEVE W.
  • 15,405 POSTS
Welcome to 2CarPros.
The 3.6 in your Journey has a few known issues.
One of them is rocker arm failure, specifically the bearing in the roller that rides on the camshaft fails and you hear a clicking sound. Usually, if you can hear it you will need at least that rocker and the camshaft. Possibly more.
Another issue is the flex plate between the engine and transmission cracks and causes noises. Both of these can cause it to go into limp mode. There are a few others but none that generate noise until they fail completely, then the noise usually comes from the owners mouth, and isn't pleasant to hear. First thing to do would be to scan the system for power-train codes. This will give you a place to start. Another test would be to take a piece of hose or a mechanics stethoscope and use it to listen to the various parts of the engine and follow the tick to it's source. That would get you at least in the area of failure and if it's around the transmission and not the engine it will help narrow it down. If possible could you record a video of the noise close in to the engine and another toward the transmission and upload them here? That may also help us give you a better idea of the fault.
Jan 8, 2019 at 6:11 AM
