Loud squeaking
2006 DODGE STRATUS
108,000 MILES • AUTOMATIC
SMH3
My car is making a rather loud squeaking noise when i make turns it will even squeak when parked after running for a few minutes and when going over bumps. Sounds like its coming from passenger side front i greased thr ball joints on that side seemed to quite a lil but still loud i then replaced uppper ball joint drove it around for 5 min seemed as if noise was gone next day drove to work noise was back just as bad. Also i can hear it squeak when i push up and down on passenger side front end. Please help me out here.
Jan 27, 2016 at 11:02 AM
JOHNNYT73
  • CERTIFIED EXPERT
  • 924 POSTS
I would check your control arm bushings, sway bar bushings, lower ball joints, and strut mounts/bushings.
Jan 27, 2016 at 11:10 AM
