Loud noise
140,654 MILES • 1.8L • 4 CYL • AUTOMATIC
DALLEENLOL02
I took my car for a two hour drive after my car cut off when started, but if you rev it up and put in gear it would stay running but if rpm went below 1 or you stopped it would cut off. added oil, still about the same. had spark plugs changed and added two more quarts of oil. it stopped after a week or so. it started making a loud noise that would get louder when given gas and cutting off again. also added oil when sparks done it was low added quart off oil and so gas additive for knocking didn’t help.
Jan 17, 2019 at 9:27 AM
  • 55,743 POSTS
Does the noise come from the engine? Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response. We should run the codes as well to see what comes up
Jan 18, 2019 at 12:05 PM
