Loud engine noise and irregular RPMs?
133,000 MILES
MRLNBLK
My car will start up with a loud whirring noise that doesn’t go away aside from a few random minutes here and there, driving or parked. It is idling and accelerating irregularly, and the RPMs will sometimes drop in the middle of driving. Say on the highway I'm going 65 MPH steadily; the RPMs will sit at about 2,300 and drop to 1,500. I had similar problems last year at the same time, which got to the point my engine was shutting off on the road. I replaced my starter, so I’m hoping that isn’t the issue.
Mar 22, 2023 at 8:17 AM
  • 110,248 POSTS
Is the check engine light staying on while the engine is running? Also, can you tell approximately where the sound you hear is coming from? Could it be from the fuel pump?
Next, if possible, could you record the engine noise you are hearing and upload it for me to hear?
Take a look through this link and let me know if anything could mirror what you experience:
https://www.2carpros.com/articles/engine-noises
Let me know as much as you can. Also, if I could actually hear it, it should help a lot.
Mar 22, 2023 at 1:05 PM
