loss of throttle when put in gear
1991 MITSUBISHI MIGHTY MAX
190,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JWWOOTEN
When I first start the truck it idles verv low. When i give it fule it sounds as if it is going to flood out
afta few minutes it idles up then the accelerator works fine. But as soon as i put it in to gear i lose all acceleration. I have to hold in clutch or take out gear and play with gas peddle till accelerator begins working again. But it will go out as soon as i put it back in gear.
Sep 2, 2015 at 3:43 AM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. 38 psi w/vacuum 47-50 w/o at idle.
Sep 2, 2015 at 7:41 AM
