Loss of power, flashing check engine light, trouble codes PO451, PO300, PO301, PO302, PO303, PO304 and PO314
145,000 MILES • 4 CYL • 2WD • MANUAL
JEN SMITH
I backed out my car yesterday and all was fine. Pulled out n 1st gear, still fine. Got to end of road and went to pull out n 1st gear but it felt like I was in 3rd or 4th gear! No power at all! Check engine light started flashing (just to be honest, the check engine light has been on solid for a little while now but I was not experiencing any issues). I turned around and went back home rather than drive it any further and when i got out there was a strong "burnt" smell, not an electrical smell but like a burnt rubber or just a hot, burnt smell. The next day I hooked it to a computer and it gave me the following codes: PO455 (this exact same code came up twice, it was the very first code and then it came up again after code PO451) , PO451, PO300, PO301, PO302, PO303, PO304 and PO314. Any ideas where I should begin here???
Feb 8, 2021 at 7:23 AM
  • 110,248 POSTS
The codes you have break down into three different areas. First, engine misfire. Second, evaporative emissions leak, and third (P0314) a faulty camshaft position sensor. I have a feeling that is the cause of your driveability problems.
The Reno isn't offered in the US, so I don't have technical information specific to this vehicle, but that is where I would start.
Here is a link that explains how in general to replace a camshaft position sensor. Hopefully, you can use it as a guide.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Take care and God Bless,
Feb 8, 2021 at 10:02 AM
