I have an intermittent issue with my van. it will randomly turn off while driving or idling and some times it starts right back up most times it takes a lot of tries. it can happen after ten minutes of driving or after two hours of driving. never the same time period. when it happens it is like the ignition was turned off. some times while I am driving and it turns off I put the car in neutral to try to restart it and before I can turn the key it turns back on.(not all the time). Now I need to pull over to put it in park to get it to start after several tries. now the dash lights and parking lights stopped working. I replaced the instrument cluster and the dash worked for a few days but now it is not. The main issue is the shutting down problem. I did a scan and got codes P0600 and P1698 once no codes since last shut down.do I need to replace the BCM or TCM?
any help is appreciated. I cannot afford a new car.
Feb 19, 2018 at 3:46 AM
