Got it. I wish you would have given me numbers. Okay is not good for me.
Anyway 132 below. Looks like a wiring issue with the O2 sensor.
P0132
Descriptor
1/1 O2 Sensor Shorted To Voltage
O2 Sensor 1/1 Voltage High
Probable Causes
Intermittent Condition
Oxygen (O2) Sensor
Oxygen Sensor (O2S) Above 3.7 Volts
Oxygen Sensor (O2S) Ground Circuit Open
Oxygen Sensor (O2S) Operation
Oxygen Sensor (O2S) Return Circuit Open
Oxygen Sensor (O2S) Signal Open
Oxygen Sensor (O2S) Signal Shorted to Voltage
Powertrain Control Module (PCM)
Powertrain Control Module (PCM) Return Circuit
Powertrain Control Module (PCM) Signal Circuit
134 is for O2 staying at center. Possibilities below but also could be from clogged cat converter.
P0134
Descriptor
1/1 O2 Sensor Stays At Center
Probable Causes
Oxygen Sensor (O2S) Ground Circuit Voltage Drop
Oxygen Sensor (O2S) Signal Circuit Voltage Drop
Friday, February 15th, 2019 AT 12:49 PM
