loss of ignition- run/start
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JOSH KING
code reader says "56 loss of ignition-run start" on the occupant restraint module. The fuses are all good. Is this code re-settable on the ORC?
Jan 15, 2022 at 7:14 AM
  • 110,248 POSTS
To get the code, did you use a scan tool, did it turn on itself, or did you perform the instrument panel self-check? If you used a scanner, it should be a letter followed by a 4-digit number. For example, P0300.
If you have a scan tool, check to see what codes are stored. I went through the double-digit codes looking for 56, but nothing is listed. It jumps from 54 to 60.
Let me know. Also, let me know if there are any other issues you are experiencing.
Jan 15, 2022 at 11:51 AM
JOSH KING
I tested the module individually with my code reader. That is where it says loss of ignition in the ORC module. The problem with the truck is that the ASD relay is not getting ground signal from the computer and therefore not closing. I was thinking the computer might not send that signal if the airbag control stops it.
Feb 15, 2022 at 10:22 AM
  • 110,248 POSTS
Loss of airbag control won't prevent it from running. It sounds like the PCM may have failed if you are not getting a ground signal. Have you checked the connector for corrosion or damage to the pins?
Feb 15, 2022 at 10:55 AM
JOSH KING
The camshaft and crankshaft sensors are going from 0 to 5 volts when the motor is rotated. PCM is getting ignition signal. grounds are good. I disconnected all the O2, transmission, AC pressure sensors, Probably the PCM is bad. I have a donor truck to pull another computer from.
Feb 15, 2022 at 11:00 AM
  • 110,248 POSTS
If the signal voltage to the CKP and CMP are jumping around, something is causing an issue. That should be steady when cranking. Either the PCM or a poor connection.
Let me know what you find.
Feb 15, 2022 at 11:08 AM
JOSH KING
My understanding is that the CMP and the CKP send a square wave from 0 to 5 volts as the engine is rotated manually. Not with starter. Is this not the case?
Feb 16, 2022 at 4:00 AM
  • 110,248 POSTS
When I use an oscilloscope, I crank it with the starter. Is that what you are using? If you are turning it by hand, I don't see how you could check for a crank/cam correlation.
Try cranking it and let me know the results.
Feb 16, 2022 at 8:20 AM
