Loose Hose
165,000 MILES
JACKIEMARIEILY
My Daewoo leaks Tranny fluid everywhere, someone disconnected a hose and couldn't put it back/couldn't remember where it went. It comes out of the red cap for the tranny fluid, and just sits inside under the hood leaking everywhere, Where does this hose go and what is it called? Is it the Transmission Cooler Pipe or Hose? and also, I read somewhere that it was supposed to just there not connected to anything; however, that doesn't make sense to me because then the fluid leaks out everywhere...so am I missing something then or is what I read from a complete moron?.
May 15, 2013 at 11:16 AM
transmission cooler line. yes, it has to be hooked up.
why was it dis connected??
May 15, 2013 at 11:28 AM
JACKIEMARIEILY
I have no idea why, but it was. So, do you have a diagram of where it is supposed to be? or can you try to explain it?
May 15, 2013 at 11:47 AM
