Loose gear stick
130,170 MILES • 1.6L • MANUAL
LOKI13
Gear stick as suddenly became quite loose?
Mar 1, 2019 at 12:54 AM
BMDOUBLE
  • 1,139 POSTS
There are rubber bushings at the end of the shifter cables that crack and fall apart, thus they do not stay attached to the linkage. You will have to replace the cables. I had to tie strap mine to get it home, they are on the driver side in the engine compartment.
Mar 1, 2019 at 12:08 PM
