Locked up front seat (Passenger side)
184,000 MILES
DONSCISCO
Cannot adjust front passenger seat. Moves ever so slightly either back or forward. Appears to be off track. Motot works fine. Checked for obstructions and nothing appears to obstruct seat movement. Seat moves forward slightly left or right. Does this appear something I could correct other than taking to Lexis shop?
May 11, 2013 at 3:26 AM
HMAC300
  • 48,601 POSTS
it cold be the switch or motor not operating correctly check your wiring under seat to see if it has hit someplace also check to see if there is spring that has come disconnected from oneside to other. sounds morelike a motor though.
May 11, 2013 at 6:21 AM
