Locked motor or do i have a shut off switch
2005 CHEVROLET EQUINOX
108,000 MILES • 4.2L • V6 • AUTOMATIC
BRAE329
One day i pulled in the driveway and my car just cut off while driving. I thought it was the battery so i bought a new one. When the mechanic put the battery in and i tried to start it. It and made a light clicking noise and wouldn't turn over. He said it sounded like the motor was locked. We checked under the hood i had zero oil. But no engine lights or nth came on. i just got my head gasket replaced a month or so ago and oil change May 2. I am assuming the oil leaked out. But now i am trying to figure out if my motor is locked? Or maybe i have a shut off switch. The mechanic who looked at it just said it sounded like it could be locked.
Aug 14, 2019 at 10:37 PM
STEVE W.
  • 15,347 POSTS
Welcome to 2CarPros. An easy way to check the engine would be to put a wrench on the crankshaft bolt in the balancer and try to turn the engine over by hand. If it turns over that way but the starter will not turn it then it could be a bad starter. I also would verify the lack of oil. Unless there is a lot of oil sprayed under the car or large puddles I would doubt it leaked out. Best way to do this would be to simply drain the oil like you were doing an oil change. If you remove the drain plug and get very little oil out then you have a problem.
Aug 14, 2019 at 11:23 PM
