Loss of water
OLDCROW37
  • LINCOLN TOWN CAR
1997 town car signature fuel injected v8
137000 miles.
I loose water over time and there are no leaks that I can find. The temp gauge sticks on cold and no heat for a long time then it jumps all of a sudden. Some times the gauge will go HOT and the water may be down 2quarts. Is there a sensor that would cause this or what do you suggest?
Thanks,
Cliff
Saturday, March 24th, 2007 AT 8:08 AM
MIKE H R
  • 3,094 POSTS
Let me know if what I understand is right, the car has no heat and the temp guage shows cold< then
it runs hot, I would start with the thermastat, it could be going bad, keeping it open then closing causing the difference in the temp. On the sending unit there is a wire, ground the wire and watch the reaction on the temp guage it should go to the hot position, you can have the coolant system pressure checked to see if it holds the pressure. This would tell if there is a leak.
Saturday, March 24th, 2007 AT 9:01 AM
