ABS
LINCOLN TOWN CAR
SHELLS
Hi all, I'm new here but I'm hoping that someone can answer a question on the ABS module under the air filter on a 97 Lincoln Town car.
I just bought the car in Ohio and after driving back to Colorado the brake lines blew out driving down the mountians here... very scary indeed.
The lines crumbled when I took them off and it's anybodys guess why they even worked.
The issue is when I'm replacing the lines is knowing which lines goes into the ABS block. ? There are 4 outputs on the ABS module and beause the lines just fell apart I can't even trace which goes to where...
Can anyone help? Lincoln service is lost.
Shell
Jun 28, 2006 at 3:43 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
need to locate another car and look, sounds weak but dont know what else to tell you....sorry
Sep 12, 2006 at 3:17 PM
