Interesting - I have a 2003 town car and just finished fixing my hard to steer problem-
As I understand it, the steering system on these cars are a bit more complicated vs standard system. The pump produces pressure, which is actually regulated by a proportional pressure valve, this valve provides the required pressure in accordance to the pressure switch on the steering line, I believe it's called a low-pressure switch. This is to maintain a certain amount of pressure thus (feel on the steering column). So, knowing as little as I do, I went and replaced the intermediate shaft (Lower) which was binding by the way but my problem remained. I then checked wiring on that valve which is located on the right side of the rack looking from front of car. Looked good, so I replaced the pump. And the problem got worse, I was like, great ready to junk this POS. So today I decided to remove the lower shaft and see if I could actually turn the rack and pinion by turning the shaft that connects to the lower intermediate shaft, I could not, not enough room. But you know what I did? I put the front car on jacks, opened the reservoir and kept the cap open, then I manually moved the wheels left to right, right to left and oil started coming out of the reservoir, this is without motor on.
What was happening is that when I pushed to one side and then tried to push to the other, there was a like air on the line or something because it started easy then hardened, I did this enough times to eliminate the easy part and the wheels moved at the same resistance left to right. I greased the upper u-joint and returned the shaft (lower shaft), since I did not find any binding when moving the wheel, I realized that there isn't anything wrong with the rack and pinion, this had to be either electrical or air on the line.
I went into the car and turned the wheel (car still up in the air- turn your air suspension switch of btw) and everything seemed okay, so I lowered the car and started it. turned it left to right with little pump noise until it went away and so did my problem.
I bought this car as it was, so I had no history to go by. On this car it turned out to be the shaft which I replaced, the upper shaft which I lubed and air on the line which I just showed you how to internally bleed this system.
Great cars, I love these Lincolns I really do but could have done without the controlled power steering system. Good luck hope it helps someone.
Oct 9, 2021 at 8:58 AM
