1994 Lincoln Town Car runs bad wen engine cold.
SUNNYBEGOOD
Engine problem
1994 Lincoln Town Car V8 Wheel Drive Type unknown Automatic 143425 miles
Car runs very bad when cold does not have power but wen i let it wom up it's fine.Firestone did a fuel system check clean injectors,this was two mouth's ago.The gas I use is chevron never change gas comp.
Dec 21, 2007 at 8:46 AM
BLACKOP555
  • 10,386 POSTS
the MAF sensor should be cleaned first if equipped.
next change the coolant temp sensor and clean the inside of the throttlebody.
the IAC may also be failing.
Dec 21, 2007 at 9:35 AM
