1994 Lincoln Town Car Overheating
1994 LINCOLN TOWN CAR
196,884 MILES • V8 • 2WD • AUTOMATIC
VALERIOSG
My 1994 Lincoln Towncar Signature Series keeps overheating. I have change the thermostat, EGR valve and gone through 6 gallons of anti freeze in about two weeks. I can not figure out the problem. Please advise. Thank You in advance.
Mar 8, 2010 at 9:34 PM
RACEFAN966
  • CERTIFIED EXPERT
  • 5,029 POSTS
OK if you are going through antifreeze you are using or leaking. I would have a pressure test done to see if the cooling system is holding pressure. I would also check the intake make sure it isn't cracked or anything. Is the intake plastic or?
Mar 9, 2010 at 9:28 AM
