1989 Lincoln Town Car steam coming from exhust
BOTCH127
  • 1989 LINCOLN TOWN CAR
  • V8
  • 17,600 MILES
Car runs but has steam coming from exhust
Wednesday, April 8th, 2009 AT 8:20 AM
MERLIN2021
  • 17,250 POSTS
Do a pressure test, and compression leakdown test, these cars had issues with intake manifold gaskets, and corrosion at the corners of the heads and manifold, a pressure test will show the leaks, you can also remove the spark plugs and see if any are discolored or wet. If it turns out to be the more severe head gasket problem, you can try this if you don't want to replace the gaskets.
Wednesday, April 8th, 2009 AT 8:45 AM
Related General Content
