2004 Other Lincoln Models Cylinder location/firing order
2004 LINCOLN
50,000 MILES • V8 • 2WD • AUTOMATIC
DAVIDNVEGAS
I just need a diagram or help to show where cylinder #5 is at, I have a check engine and it says misfire on cylinder 5 and I've changed spark plugs and coil pack and still the same intermtent problem only comes on some times in idle? I first want to make sure I'm replacing the right one. Thank you.
Apr 9, 2009 at 3:06 PM
  • 75,988 POSTS
2004 Other Lincoln Models V8 Two Wheel Drive Automatic 50,000 miles
What model is this? describe it may be I can help.
Apr 9, 2009 at 3:26 PM
DAVIDNVEGAS
The light only comes on ocasionally at idle. I can feel/hear it miss and the light blinks to say it is missing, but I've changed plugs all around and replaced the first coil pack on the drivers side towards the front of the car wich I believe to be #5. And after sitting at a light for a while it starts again. Very frustrating esspecially because we were in California on vacation when it started. I keep hooking it up always says #5 misfire. Position sensor maybe? I don't think it is a mech. problem as it is very intermiten. But thank you any help would be very kind, and appreciated!
Apr 10, 2009 at 3:54 AM
  • 75,988 POSTS
Misfire at no.5 -check the compression and injector
Apr 10, 2009 at 10:14 AM
