2003 Other Lincoln Models Gear Shift Was Loose
2003 LINCOLN
78,000 MILES • V8 • 2WD • AUTOMATIC
DJINANA
Hello...
I pulled up to my daughter's school today, came to a stop and shifted into park. As i shifted, I noticed it felt very loose and my car would have rolled if did not apply the brake (and parking brake).
I also could not restart the car.
I called AAA and he looked underneath and apparently snapped a cable back into place (something about the gear shift cable coming loose).
He said I should be okay, but I should take it in soon so it doesn't happen again.
Have you heard of this before? What should i do?
Feb 19, 2010 at 5:12 PM
HMAC300
  • 48,601 POSTS
there may be a clip that holds the cable in place or from the use over the years may have worn it's mounting a little. Take it in an dhave it checked, the mechanic may be able to tighten it up or there may be a tech service bulletin for a different clip that holds it better.
Apr 18, 2010 at 10:54 AM
