1998 Lincoln Navigator Code P0308 with liquide GAS
243,000 MILES • V8 • 4WD • AUTOMATIC
WILLIAM0564
Dear reader
My Car is drive in petrol as on liquide GAS
When cold or warm and i stared the car there are no problems even when i drive normal
BUT at the high way and the car is driving between 70 and 80 Km/h the transmission is going in a higher gear and at that point the car is walking rough. When i take a bit gas (power) back it´s runnig better.
At 120Km/h and give full power again the car is walking rough and at that point the light is burning " Check Engine" take power back and afther a few sec. light goes out and with a ODBII you read NO code´s.
When driving again fast with full power and the light goes on again and you check with the ODBII it say P0308, so misfire at number 8
Please note that we put in new full injectors, new Coils and sparkes (all .8.)
ONLY this problem is with liquide GAS, so i think wrong sparkes.
Now there are Bosch 26+ inside, what you think i can use the best for solveing this problem?
William
(From the Netherlands)
Sep 29, 2010 at 8:23 AM
  • 75,988 POSTS
Hi william0564, Welcome to 2carpros and TY for the donation
P0308 -A specific cylinder misfire should prompt you to check the sparkplug, compression and injector for cylinder no.8
Sep 30, 2010 at 3:52 AM
WILLIAM0564
i find out that the new Bosch sparks i put in has 1.1 MM distans it´s to big for driving on liquide GAS.
So i put in ACDELCO 41-812 with 0.8MM this most resolve the problem
I wil put them in today and i let you know how it ends :-)
Thanks
William
Sep 30, 2010 at 6:37 AM
