1994 Lincoln Mark VIII bleeding
1994 LINCOLN MARK VIII
120,000 MILES • V8 • 2WD • AUTOMATIC
RWHITMER71
I am trying to bleed the cooling system on this car and was informed it had to be bled. I have no idea where the bleeders are located or what to do when i find them. can you terll me the locatiobn and the proceedure?.
Nov 9, 2010 at 6:56 AM
DOCFIXIT
  • 18,828 POSTS
No bleeder on engine run with cap off till all air expelled. What is problem?
Nov 9, 2010 at 7:06 AM
BLUECOLLAR
  • 86 POSTS
Theres a plug on top of the motor that has a 1/4 drive square hole to remove it. Remove the plug and run the engine. The air will escape allot quicker.
Feb 6, 2011 at 10:30 AM
