Brakes problem
1990 Lincoln Mark VII V8 Two Wheel Drive Automatic
After driving and using the brake on a stop and go the pedal gets harder and harded then i have to stop turn the engine off and pump the brakes to bleed the pressure off, some times it works and sometimes not good enough, park it for a night and its fine until you get back in the stop and go. Brakes are locking because you can smell it.
Aug 21, 2010 at 2:52 PM
