2002 Lincoln LS oxygen sensos
SALGADO23
  • 2002 LINCOLN LS
  • 6 CYL
  • 110,000 MILES
Check engine light recently turned on. I did own diagnostic check, problem stated left side running too lean.
my bro states the issue is oxygen sensor. Any assistance would be appreciated.
Friday, November 21st, 2008 AT 12:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
O2 sensors are rarely the problem here, although they seem to be the component that people replace first. I would suggest checking your vacuum hoses to ensure they are not pinched or loose. Could also be the PCV valve needing cleaned or replaced as well as your spark plugs and wires needing replaced.
Friday, November 21st, 2008 AT 12:38 AM
