2001 Lincoln LS 6 cyl Two Wheel Drive Automatic
I have a 2001 lincoln ls. The car is misfiring. When you floor the gas it takes a while for it to gain power and it is sputtering. I have cleaned the injectors. Check the coil paks. Check spark plugs. Check wires. Check vacum lines. Would could be the problem?
SPONSORED LINKS
Sunday, February 15th, 2009 AT 7:39 PM
