2000 Lincoln LS Catalytic converter
134,000 MILES • V8 • 2WD • AUTOMATIC
DTG25
hypothetically, what would happen if you removed the catalytic converters from a 2000l lincoln ls?
Sep 4, 2010 at 9:18 AM
ERNEST CLARK
  • 1,730 POSTS
You wouldn't pass an EPA inspection and your computer would through you a code thinking your cat is clogged and/or the O2 sensor after the cat is failing.
The computer will compensate and the car will drive fine.
Sep 19, 2010 at 10:44 PM
