2000 Lincoln LS Car won't start
MARKOH
  • 2000 LINCOLN LS
  • V8
  • 90,000 MILES
Our car turns over but will not start. The computer is saying fuel data error. How do we fix this?
Sunday, October 31st, 2010 AT 9:09 AM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, November 2nd, 2010 AT 2:25 AM
