Engine Mechanical problem
1998 Lincoln Continental V8 Two Wheel Drive Automatic
locations thermostat lincoln continental 1998
Saturday, January 30th, 2010 AT 1:54 PM
BLUELIGHTNIN6
MECHANIC
Thermostat Is Located Directly Behind The Radiator And Fan Shroud. There Are 3 Hoses Going Into The Housing For The Thermostat Which Should Be Taken Off Before Exposing The Thermostat To Make Changing It Easier. There Are Also 4 Bolts. 2 10mm And 2 8mm.
SPONSORED LINKS
Saturday, January 30th, 2010 AT 3:06 PM
JIMMYMORA
MEMBER
1 POST
Thanks to evacuate my doubts its aid is very effective.
