1998 Lincoln Continental how to change thermostate
18,000 MILES • V8 • FWD • AUTOMATIC
STEVELAMPERT2
180'000
Aug 2, 2010 at 12:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
from the driver's side at the bottom of the radiator the hose runs across to the passenger side of the car. it turns up into a housing with a secondary smaller hose coming out the side of the housing. if you remove the 2 bolts holding this housing together you will find the thermostat inside with an O ring seal that has to be replaced in the right position when you reinstall the new thermostat.
Aug 2, 2010 at 12:59 PM
