1996 Lincoln Continental air ride system
BRENDA GEORGE
  • 1996 LINCOLN CONTINENTAL
  • V8
  • FWD
  • MANUAL
  • 163,000 MILES
The air ride will not pump up. When you turn it on the motor will run for about 5-6 seconds and then turns off. I have replaced the air pump[ and the dryer what else can it be the left side is lower than the right.
Saturday, March 15th, 2008 AT 2:51 PM
MERLIN2021
  • 17,250 POSTS
A line, or solinoid, or spring itself, use a spray bottle with soapy mix and spray the parts tell you can find the leak, you problem now is unles you have a scan tool that can command the system to fill, it won't.
Saturday, March 15th, 2008 AT 2:55 PM
