1995 Lincoln Continental Car won't turn off when ignition t
CARLUCCIJA
  • 1995 LINCOLN CONTINENTAL
Electrical problem
1995 Lincoln Continental V8 Front Wheel Drive Automatic
Just bought the car. Replaced some fuses and turned the car on then off. The engine still ran. Pulled out Fuse number Five which deals with the LCM and run start sensor. Then the car shut off. What could be causing this.
Sunday, August 24th, 2008 AT 3:29 PM
MERLIN2021
  • 17,250 POSTS
You probably need a new switch, not the key, but the plastic switch the harness plugs into.
Sunday, August 24th, 2008 AT 3:38 PM
CARLUCCIJA
  • 29 POSTS
The ignition starter switch?
https://www.2carpros.com/forum/automotive_pictures/67002_ig20511_1.jpg
Sunday, August 24th, 2008 AT 3:48 PM
MERLIN2021
  • 17,250 POSTS
Yes!
Monday, August 25th, 2008 AT 5:45 PM
