DCL or Diagnostic Connector Link is located in the trunk on the left side, behind the carpeting right where the rear left tire wheel well starts up from the trunk floor. There should be an opening in the carpet and the wire is pined to the metal support plate there. Als mounted just below that is a switch for the air ride suspension, as well as the fuel cut off switch.
SPONSORED LINKS
Saturday, January 9th, 2010 AT 5:55 PM
