Limp mode
200,000 MILES • 4 CYL • TURBO • 2WD • MANUAL
PETAR.MILOVIC
My car listed above 1.9tdi 85kw has a problem that really annoys me. When I drive above 100 km/h car suddenly loses its power and cant accelerate. When I turn car off and on again it work but same problem is happening above 100 km/h speed. I plugged car to diagnose the problem and it showed no errors. I did change fuel filter and oil and oil filter recently. Can someone help me please? Thanks in advance.
Feb 27, 2019 at 11:42 PM
  • 55,694 POSTS
This is common because the throttle body gets dirty causing a corrosion issue forcing the car into limp mode. here is a guide to help fix the problem:
https://www.2carpros.com/articles/reduced-power-limp-mode
Mar 1, 2019 at 5:35 AM
PETAR.MILOVIC
Thank you very much.
Mar 1, 2019 at 5:42 AM
  • 55,694 POSTS
Mar 2, 2019 at 3:42 AM
PETAR.MILOVIC
I was at dealers shop, looks like my turbo charger needs reparation. Thank you very much for your time. Cheers
Mar 8, 2019 at 6:46 AM
  • 55,694 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Mar 9, 2019 at 4:46 AM
