ABS light on on dashboard
126,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
FLIPPA334
  • 42 POSTS
Why is my ABS light on and what does it mean?
Dec 12, 2018 at 4:24 AM
Good afternoon,
The ABS system has a fault stored in the module. You can have the code read at any parts store. Once we know the code, we can further help you narrow the are of failure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
With the light on, you can still drive the car and the brakes will work fine. The ABS will be out of service until the failure is repaired. The most common issue is the wheel speed sensors but the code will us narrow the area of failure.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Dec 12, 2018 at 5:03 AM
FLIPPA334
  • 42 POSTS
I will let you know what the code reads once I take it to a part store.
Dec 12, 2018 at 10:28 AM
Sounds like a plan.
Dec 12, 2018 at 10:29 AM
