2001 Lexus RX 300 rebuild or replace transmission?
2001 LEXUS RX 300
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCHNEID
2001 Lexus RX300 seemed to be running fine, then made a "squeeling noise" at start-up, which went away after 5 mins of driving. After 2 weeks of the start-up noise, the transmission went totally out, and the car would not go into any gear - although the gear shifter did move up and down. How much should a typical rebuilt transmission cost? Should I have it re-built? or look for a used transmission to replace the old one? Cost for rebuilding? And cost for replacing with a used trans?
thank you
Mar 16, 2010 at 1:38 PM
DAVE H
  • 13,384 POSTS
have the vehicle looked at by a good transmission shop .. it may be just an electrical fault which cna be easily remedied .. or they can plug the vehicle into a diagnstic scanner to locate the cause of the fault and better quote repair costs
Mar 21, 2010 at 1:33 AM
