2000 Lexus RX 300 RX300 Battery Drain
2000 LEXUS RX 300
78,000 MILES • 6 CYL • AWD • MANUAL
WILDRON
The battery in my Mom's RX300 goes dead if not driven for about two weeks (she has another car). I has traced a parasitic current draw down to two circuits. With the ammeter connected to the negative battery cable and the battery post (cable disconnect), I get 0.596 amps. With DOME fuse removed I get 0.300 amps. If I remove the ECU-B fuse I get 0.387 amps. No lights in the DOME circuit are on, I checked them all. No check engine light is all. Everything works fine and if driven everyday the battery stays fine. I assume the ECU-B requires current to operate the alarm system when the ignition is off. If the problem is in the DOME circuit I have not idea how to diagnose the problem. Any advice would be greatly appreciated.
May 30, 2009 at 5:10 AM
DOCFIXIT
  • 18,828 POSTS
Are you using the milli amp scale or 10 amp? A .5 milli amp is about right for that car but .5 amp is not
Does car have vanity mirrors ? if so see if on when lid shut also ckeck trunk light and glove box.
May 30, 2009 at 5:27 AM
WILDRON
Yes, I'm using the 10 amp scale. I've checked all the lights, both dome lights, the glovebox, light, the vanity lights. I've even checked the car at night. I can't find any lights on. I'm suspecting the body ECU, but I don't know how to check it. Any ideas?
I'm little confused here. Using my mutilmeter I get about 0.6 amps when I connect the leads to the negative battery cable and the post. When I switch to the mA scale (changing the leads on the meter) I get about 0.15. What am I doing wrong? Shouldn't I be getting about 600 milliamps?
May 30, 2009 at 5:10 PM
DOCFIXIT
  • 18,828 POSTS
That's why I asked test is started out on 10amp scale when first connect battery variuos relays and ECU are powered up. Then you set on milli scale this reads parasitic drain .5 milli is acceptable. Have recommended to many owners that leave car at airport for week or more to get a solar panel plugs into cig lighter will keep batt up.
Jun 1, 2009 at 7:00 AM
