1992 Lexus - No Heat
1992 LEXUS
TBALON
My car does not put out heat. I changed the radiator fluid and the thermostat, still no heat. Please suggest other things to check.
Thanks.
Tom Balon
Jan 19, 2006 at 7:27 AM
DIVADAYNA25
Have the same problem....it's the heater core. Can almost guarantee it!
Jan 19, 2006 at 11:22 AM
DAVE SOMMER
could also be another couple of reasons. you have air in the heater matrix which needs bleeding or you have a blockage in the matrix itself. remove heater hose from one side of the matrix and connect a hose pipe to it and flush out. as for the air pocket:- disconect hose from return side of the matrix whilst engine running and wait for hot water to come out or look for a bleed screw on the hose
trigger
Jan 25, 2006 at 11:36 PM
