2002 Lexus LS 430 A/C filter, timing belt and spark plug
2002 LEXUS LS 430
75,000 MILES • V8 • FWD • AUTOMATIC
TIMKAO
Dear Mr.:
I have a 2002 Lexus LS430. It has been driven 75,000 miles. I recently changed air filter a week ago, but after that, my car's instrument always shows "change A/C filter", but my car is still running normally. Would you please tell me what's happened or if I did something wrong, and where the A/C filter is located. Also, I would like to change the spark plug, but I'm not sure where the correct location is and after how many milles will I need to change the timing belt. Thank you.
Sincerely,
Tim Kao
Dec 11, 2008 at 9:06 PM
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
WHILE THE VEHICLE OFF HOLD THE OFF BUTTON ON YOUR CLIMATE CONTROL , NOW TURN THE KEY TO THE ON POSITION , MAKE SUR E YOU DONT RELEASE THAT BUTTON FOR 30SECS
THE A/C FILTER IS NOW RESET
A/C FILTER SHOULD BE REPLACED IN 15K INTERVALS
TIMMING BELT SHOULD BE REPLACED IN 90K INTERVALS
PLUGS SHOULD BE REPLACED IN 90K INTERVALS
HOPE THAT HELPED
Jan 17, 2009 at 6:35 PM
